Troubleshooting... strong signals now faint
russellv2
Genesee County, MI
Something happened with my 296 this last weekend.
All of the sudden, with no explanation, and no change of settings I am having a hard time receiving local signals on my scanner. I have checked all settings, no attenuation set. No loose connectors on the radio nor on the antenna feed line. I plug either my 796 or my 750 into the same antenna and recieve those stations strongly. As an example... on my 296 and 796, I used to get my local sheriff department dispatch frequency full scale on the little bargraph that's displayed. On my 796 I still get full scale, on the 296 I'm lucky if I get a bar or two.
Any ideas?
mancow
N.E. Kansas
I think Uniden has a problem with the receiver amp transistors getting easily fried by static charges through the antenna.
This exact same thing happened to my 250d. The repair documents noted a transistor was replaced. I've heard of others with this same problem but mostly with the 250d.
mancow
russellv2
Genesee County, MI
Oh crap! I was hoping it wasn't going to come to that. I hoped I had just overlooked some small setting. Oh well... thanks for the help and the possible answer.
Colin9690
County 21
APE282018
It could be as simple as just blowing on or cleaning the antenna connections.
russellv2
Genesee County, MI
Thanks for the help, though I already tried that. Didn't help. I tried shooting a drop of contact cleaner on the connector too. I also tried to gently bend the contacts in the connector to "squeeze" the center of the BNC connector... that helped a little, though it's still not muh improved.
Colin9690
County 21
APE282018
thats weird, I've had minor reception problems with my -93 before, but all that i needed to do was blow out some dirt and dust. I'm puzzled with your situation.
russellv2
Genesee County, MI
I'm puzzled too. This is the first and only problem I've had with any of my radios that wasn't "user-induced" as far as I can tell. LOL It hasn't even been dropped on the ground since sometime over the summer. :p
