Troy police
elman26
Albany New York
Hi I live in Colonie,I just pruchased a bcd996xt scanner .I put Troy in it but I cant recieve anything. I put in in correct as EADCS NARROW/WIDE with the freqeuncies in the correct order but nothing. am i too far away? Im only in colonie.Am I skipping something? Please help.
jgorman21
Glenmont N.Y.
Troy PD
Troy is difficult to receive. It depends where you are. I know down here in Glenmont, I can get them in certain parts of the house on the portable. I think they have a very low power signal - probably by design!
D
DaveNF2G
Guest
Troy's system is located on the east side of the Watervliet water tower and is blocked to the west by the tower itself. It is also relatively low-powered. The idea was to cover the City of Troy and not much else. It works.
Thunderknight
Bletchley Park
Try taking the scanner over to the east side of town, like around the K-Mart on Route 2 and see what happens. If you can't receive it there, you have a programming issue.
(Of course, transport that scanner in some legal way).
If your scanner programming is good, then all you can do is try a better antenna at your receive location - try an external antenna or a yagi pointed towards Watervliet. Depending on your location in Colonie, you may or may not have luck.
Com-Tech51H8
bureaucratic absence of presence.
BEE00
troy is a low power radio system but at any rate the w'vliet tower is blocking majority of the signal so unless your within or close to the city limits your reception is gonna be horrible.
chrismol1
P25 TruCking!
I listen to Troy Police here in Halfmoon with an SRH77CA and the reception is okay, actually its really good, most likely since the elevation here is pretty high for my area. I guess you got to be either ontop on the city or get an outdoor antenna.
And the radio man said "Antenna, Antenna, Antenna"
D
DaveNF2G
Guest
Some of Halfmoon and just about all of Waterford are far enough east that the tower doesn't block the antennas for Troy.
