Trunk Recorder Broadcastify
huntingbri
I have my call log api number and node however it is not logging any calls. Do I need to download trunk recorder? Is there a link to download file using windows 10/11?
huntingbri
georgew0819
Salisbury, NC
Unzip the program and it will put the files on files needed on your hard drive. Go to the program on your C drive and locate the bin folder C:\sdr-trunk-windows-x86_64-v0.6.0-alpha4\sdr-trunk-windows-x86_64-v0.6.0-alpha4\bin. In that folder is a bat file sdr-trunk.bat which you click on to start the program. Then follow the instructions located here Playlist Editor to finish setting up your tuners and begin hearing the radio system you are trying to decode.
