Trunk Recorder Conventional & Calls
WItrunk
Wisconsin
So I have Trunk recorder setup ingesting a few different systems. I added some conventional P25 and the set up shows the two channels with a slot number is there somewhere that needs to be entered. Right now both channels are uploading to the same RR frequency.
In my JSON file I have the frequencies entered as different systems.
WItrunk
Wisconsin
My question is how do you differentiate the frequencies being ingested by Trunk Recorder and uploaded to broadcastify? There seems to be no documentation on this issue.
When setting up a new node I entered two conventional P25 frequencies in order. In the node setup area it gives me one API Key and Node ID number. Then the frequencies are listed below with a slot number, is this slot number supposed to be entered somewhere?
If I setup up the API and Node number on both entries int eh JSON file, both frequencies are getting uploaded to the first frequency.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Either in order n+1 or in your conventional cab file you specify a talkgroup and we map it to slots.
either way it’s done by slots, and normally n+1
WItrunk
Wisconsin
Thanks, I got it working now, you have to put both frequencies in the same JSON group
"shortName": "WASHBURN",
"modulation": "fsk4",
"squelch": -45.0,
"audioArchive": false,
"channels": [154445000,154092500],
"delayCreateOutput": true,
"type": "conventionalP25",
"broadcastifyApiKey": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
"broadcastifySystemId": xxxx
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
You can setup a csv file and specify the tgs (slots) for each if you want
Code:
“systems": [{
"type": "conventional",
"talkgroupsFile": "Chanlist.csv",
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
"squelch": -45.0,
I've been trying to contact you via email - your emails are all bouncing
