Trunk-Recorder "Freq: 0.000000 MHz Not Recording: no source covering Freq"
rneals
Rosco P. Coltrane
Kawartha Lakes, ON
I'm stumped on this error message in the Trunk-Recorder screen output...
Anyone have any suggestions? Anyone else see a similar no source covering freq message?
It's worth noting that it's always with this specific talkgroup as well. That seems weird, and suggest a software issue to me.
[2024-03-24 18:33:36.338223] (error) [fleetnet-fenelon] 45C TG: 2OPS05 ( 8288) Freq: 0.000000 MHz Not Recording: no source covering Freq
What I've done this far to try and solve it:
1. Added a second RTL-SDR to my system, expanding it to cover the entire 140 to 144 MHz spectrum
(which is beyond the known frequency range the Ontario Fleetnet systems uses)
2. Extended the Smartnet bandplan high freq to 144000000
BANDPLAN:
[2024-03-24 18:37:39.061764] (info) Smartnet bandplan: 400_custom
[2024-03-24 18:37:39.061770] (info) Smartnet band: 400
[2024-03-24 18:37:39.061776] (info) Smartnet bandplan base freq: 141.015
[2024-03-24 18:37:39.061784] (info) Smartnet bandplan high freq: 144
[2024-03-24 18:37:39.061791] (info) Smartnet bandplan spacing: 0.015
[2024-03-24 18:37:39.061799] (info) Smartnet bandplan offset: 380
RTL-SDR 0:
[2024-03-24 18:37:39.062011] (info) Source Device: rtl=0
gr-osmosdr 0.2.0.0 (0.2.0) gnuradio 3.10.1.1
built-in source types: file fcd rtl rtl_tcp uhd hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
Using device #0 Nooelec NESDR SMArt v5 SN: 00000002
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
[2024-03-24 18:37:39.708612] (info) SOURCE TYPE OSMOSDR (osmosdr)
[2024-03-24 18:37:39.708678] (info) Setting sample rate to: 2400000
[2024-03-24 18:37:39.832725] (info) Actual sample rate: 2400000
[2024-03-24 18:37:39.832830] (info) Tuning to 141.150000 MHz
[2024-03-24 18:37:39.887543] (info) Gain Stage: LNA supported values: 0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48 49.6
[2024-03-24 18:37:39.915443] (info) Gain set to: 14.4
[2024-03-24 18:37:39.915553] (info) Auto gain control is OFF
[2024-03-24 18:37:39.915580] (info) Setting antenna to [RX]
[2024-03-24 18:37:39.915607] (info) Max Frequency: 142.300000 MHz
[2024-03-24 18:37:39.915652] (info) Min Frequency: 140.000000 MHz
[2024-03-24 18:37:39.915680] (info) Digital Recorders: 10
[2024-03-24 18:37:39.915716] (info) SigMF Recorders: 0
[2024-03-24 18:37:39.915745] (info) Analog Recorders: 10
RTL-SDR 1:
[2024-03-24 18:37:40.140711] (info) Source Device: rtl=1
Using device #1 Nooelec NESDR SMArt v5 SN: 00000001
[2024-03-24 18:37:40.773041] (info) SOURCE TYPE OSMOSDR (osmosdr)
[2024-03-24 18:37:40.773129] (info) Setting sample rate to: 2400000
[2024-03-24 18:37:40.895019] (info) Actual sample rate: 2400000
[2024-03-24 18:37:40.895128] (info) Tuning to 143.205000 MHz
[2024-03-24 18:37:40.949744] (info) Gain Stage: LNA supported values: 0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48 49.6
[2024-03-24 18:37:40.976268] (info) Gain set to: 14.4
[2024-03-24 18:37:40.976361] (info) Auto gain control is OFF
[2024-03-24 18:37:40.976393] (info) Setting antenna to [RX]
[2024-03-24 18:37:40.976412] (info) Max Frequency: 144.355000 MHz
[2024-03-24 18:37:40.976445] (info) Min Frequency: 142.055000 MHz
[2024-03-24 18:37:40.976466] (info) Digital Recorders: 10
[2024-03-24 18:37:40.976504] (info) SigMF Recorders: 0
[2024-03-24 18:37:40.976523] (info) Analog Recorders: 10
mikewazowski
Staff member
Forums Manager
Oot and Aboot
140-144MHz is only one of 3 frequency ranges in the Fleetnet system. It's possible that the site has a frequency not within the one range you're covering.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
You could program all 3 ranges into a scanner and see what frequencies the scanner lands on or use a program capable of monitoring that type of system such as Trunk88 and see what it shows.
boatbod
Talbot Co, MD
It sounds a lot like it is failing to convert the channel id to a valid frequency. You'll need more detailed debug information to see what OSW was received and how it was interpreted.
Since you already have two rtl dongles, you could try running op25 on this smartnet system and see what it thinks is going on.
webstar22
RenfrewCountyScanner.com
Ontario, Canada
BANDPLAN:
RTL-SDR 0:
RTL-SDR 1:
I've been seeing the 0.0000mhz stuff for years, I honestly think it is something that isn't voice traffic so it never gets a voice freq assigned to it. But could also be one of those annoying Smartnet things that people hate programming for.
rneals
Rosco P. Coltrane
Kawartha Lakes, ON
BTW, I looked at Trunk88, tried to figure how to install it, and gave up after half an hour.
I didn't see any readme or install notes and couldn't figure out what the multiple different applications did.
Any clues would be appreciated.
webstar22
Ontario, Canada
I figured out the 000.0000 stuff today.
Fleetnet is adding new voice channels to sites, my local site got a new one recently so I was getting a lot of the 000.0000 issues. I had to change
"bandplanHigh": 143970000.0 to the number of the highest freq, and now the issues are gone.
141.435141.675142.125142.380c142.710c142.950
Were my freqs before but now they added in 143.9700 and my bandplanhigh didn't take that into account..
rneals
Rosco P. Coltrane
Kawartha Lakes, ON
Yep, sorry, I should have posted as follow up.
I'm also not seeing those messages any longer and also raised my bandplan high to 144 MHz.
Here's my config, using a single NooElec rtl-sdr v5.
"ver": 2,
"sources": [{
"center": 142352678,
"rate": 2400000,
"error": 0,
"gain": 20,
"digitalRecorders": 15,
"analogRecorders": 15,
"driver": "osmosdr",
"device": "rtl=0"
"systems": [{
"systems": [{
"control_channels": [142605000],
"type": "smartnet",
"squelch": -55,
"digitalLevels": 8,
"analogLevels": 32,
"modulation": "fsk4",
"recordUnknown": true,
"bandplan": "400_custom",
"bandplanBase": 141015000.0,
"bandplanHigh": 144000000.0,
"bandplanSpacing": 15000,
"bandplanOffset": 380,
"talkgroupDisplayFormat": "tag_id",
"maxDev": 3500,
"callLog": true,
"hideEncrypted": true,
"audioArchive": true,
"transmissionArchive": false,
"compressWav": true,
"talkgroupsFile": "trs_tg_2560.csv",
"hideUnknownTalkgroups": false,
"multiSite": true,
"multiSiteSystemName": "FleetNetZone2",
"multiSiteSystemNumber": 822,
"shortName": "fenlon",
"broadcastifyApiKey": "removed",
"broadcastifySystemId": removed,
"audioArchive": false
When Trunk Recorder Starts, this log spits out telling me what frequency range it can monitor.
[2024-04-12 15:11:22.384700] (info) SOURCE TYPE OSMOSDR (osmosdr)
[2024-04-12 15:11:22.384934] (info) Setting sample rate to: 2400000
[2024-04-12 15:11:22.513848] (info) Actual sample rate: 2400000
[2024-04-12 15:11:22.514117] (info) Tuning to 142.352678 MHz
[2024-04-12 15:11:22.569638] (info) Gain Stage: LNA supported values: 0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48 49.6
[2024-04-12 15:11:22.598177] (info) Gain set to: 19.7
[2024-04-12 15:11:22.598466] (info) Auto gain control is OFF
[2024-04-12 15:11:22.598615] (info) Setting antenna to [RX]
[2024-04-12 15:11:22.598749] (info) Max Frequency: 143.502678 MHz
[2024-04-12 15:11:22.598912] (info) Min Frequency: 141.202678 MHz
[2024-04-12 15:11:22.599056] (info) Digital Recorders: 15
[2024-04-12 15:11:22.599191] (info) SigMF Recorders: 0
[2024-04-12 15:11:22.599320] (info) Analog Recorders: 15
