JustPlainMike
- Joined
- Feb 23, 2007
- Messages
- 12
- Reaction score
- 0
I've been playing around with a Raspberry Pi 4 (both 4GB and 8GB flavors) and Trunk Recorder for a few months now trying to perfect the setup and recording of calls. I have two systems in my area that I'd ultimately like to feed to both Broadcastify Calls and OpenMHZ if indeed the software allows for both. I feel like I'm 95% there, but there are still a few issues. I've tried several different methods for setting it up:
Raspberry Pi OS
With this setup I've had the most success. I'm able to follow the setup instructions and start recording calls. However, they all end up being WAV format. It is my understanding that Broadcastify Calls requires MP3 or AAC format to upload to them. During the setup process I notice that the fdkacc program will not install. Is this what is causing the files to not record in the proper format? Is there another way to install it or another fix to get the right format for the files?
Ubuntu
After rereading the install instructions I thought perhaps the problem was using Raspberry Pi OS and not Ubuntu, so I went ahead and attempted and Ubuntu install. After several tries I got Ubuntu working and seemingly had everything setup to start with Trunk Recorder. I'm not sure if this is pure coincidence or a cause for the problem, but around the time I plugged in a flash drive to the USB port to test recording calls, the Pi disconnected from my network and I was unable to get the connection back. This was my only attempt so far using Ubuntu.
Docker install
I also attempted the Docker install using Raspberry Pi OS. I'll admit, the instructions to get this version running are completely confusing to me as I've never used Docker before. Maybe I'm missing something simple.
Any help getting this to run correctly would be greatly appreciated. I'll provide any additional info about my setup if requested. I do have one other issue with Trunk Recorder dealing with changing control channels, but I'll save that for a later discussion.
Raspberry Pi OS
Ubuntu
Docker install
