So I have figured out how to manually program my Whistler WS1065 scanner. I am a premium RR member. What I am having a hard time understanding is weather or not the frequency I am entering is trunked or conventional. I don't see that information when I search the Radio Reference lists. Pardon my lack of knowledge, I am new. Thanks for your patience and help.
If you're looking at the FCC licenses, look at the service code and compare against this list:
FCC Radio Service Codes - The RadioReference Wiki
Some of the more common trunking service codes are:
SY - Public Safety 700 MHz Trunked
YE - Public Safety/Spec Emerg/PS Natl Plan,806-817/851-862MHz,Trunked
YF - Public Safety National Plan, 821-824/866-869 MHz, Trunked
YP - Public Safety/Spec Emerg, 806-821/851-866 MHz, Trunked
YW - Public Safety Pool, Trunked
However, you might occasionally find a conventional frequency being used in trunked mode, or vice versa.
You may be better off using the search function of the RR database to see if a particular frequency is already identified and if so, for what.
