Yes...
Sdr dongle
Sample rate 2.4 (Anything high gave me issues)
You would need to create a new Playlist
(RailRoad)
Select that Playlist
Channels tab
New/NBFM
System ( name anything like Railroad)
Site (give a # , like 1 for BNSF / 2 for UP
Name (name for the current frequency you are setting up , like BNSF66 yard)
Source
Frequency (example 161.1)
Preferred tuner ( used if you are going to have multiple sdrs plugged in)
Decoder (NBFM)
channel bandwidth (12.5)
Squelch threshold (-50) you set the Squelch for each frequency once you are up and running
Talkgroup to Assign ( this is important for setting aliases and not getting static, you will number each added frequency 1-*)
Autostart(slide if you want the Playlist to load when you start sdrtrunk)
Click save
Go to aliases tab
New alias list (name it something like Railroad )
Click alias drop menu, select Railroad
To the left click New
Click the new alias
Alias ( enter the name you gave the frequency BNSF66 yard)
Group (example - BNSF)
Listen (slide it)
Record( slide it if you want to record)
Identifiers( here you click Add Identifier, NBFM, choose talkgroup.)
NBFM Talkgroup ( here you enter the number you added in Channel tab "talkgrouo Assign" so example 1)
Click save.
You will repeat for each frequency you add
