laser21012
I have installed trunker, but cannot get it to work. I ran the slicer program and it sees a signal on the CTS pin of com1. I have installed a directory in the root C: called trunker, in this directory I have 2 files.
1. trunker.exe
2. trunk.bat, which reads:
SET TRACKENV=C:\TRACKEN.TXT
TRUNKER
I have a shortcut on my desktop with trunk.bat to launch the trunker program.
Also in C: directory I have installed a file TRACKENV.TXT which I have the information on TRACKSLICERPORT, TRACKSLICERPIN,TRACKSLICERMODE,ETC. when I launch the trunker.bat the trunker executes and I get the trunker screen. After a few minutes I get the "wants cts". I have tried normal and inverted, but with no results. I have tried DSR,DTS,CTS still nothing. I am using an old PRO 34 as a discriminator tap. I wanted to see if this will work before I try to tap my Pro 95+96. Any help would be appreciated.
Thank you
Bob
1. trunker.exe
TRUNKER
Thank you
Bob
