Trunking a Kenwood TK 380
BenSkerker
Attleboro Ma
I was wondering if there is a easy way to trunk a Tk 380.My radio is in conventional mode and i have already filled the 250 mark for channels. I was wondering how to trunk so i can get the 600 hundred channels. I have the KPG-49D software with a programing cord any help would be great
burner50
The Third Variable
NC Iowa
Simply put,
It is not going to work like you think.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9780; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
What burner50 said x2. The 250 channel limit is due to memory limitations. Once you fill it to the max you are SOL I believe the 600 'channels' in trunk mode is talk groups, not actual RF channels like in conventional.
Thayne
Those will do 512 channels conventional, trunked is based on how they are used relating to groups-channels.
kayn1n32008
Sector 001
No they will only do 250, I own both a TK-280 and 380 and have spent a lot of time in the software. My TK-380 is a verson 2 and the TK-280 is a verson 1 and neither of them have the memory for more than 250 conventional channels.
burner50
The Third Variable
NC Iowa
600 channel capacity in trunked mode, dynamically allocating 32 system and 250 group memory capacity
250 channel capacity in conventional mode
This is probably what he found... First hit on a google search.
ramal121
Lots and lots of watts
Calif Whine Country
If you mix trunked and conventional, you'll never know what you'll get until you run out. Using the "Free Area" as a gas gauge helps.
