Trunking and Mesh - more dumb questions!
radiogrrl
Australia
HI,
this is probably going to be a silly question, but can anyone summarise what trunking and Mesh technologies are and if they are similar/compatible or completely different things?
I've only just started to look at this and am confused - is Mesh a mobile (cell) phone version of trunking or am I completely off the mark?
please help!
:? :D
N
N_Jay
Guest
Trunking is the automatic sharring of a group of channels on an as-needed basis.
Mostly used for Voice, in radio mostly used for the last link
Mesh is (Wow, mesh is hard to describe)
Mesh is the use of IP or "IP like" routing to allow a group of autonomous packet access points to create a unified network" (Maybe?)
Mostly used for (packet) data, mostly used for the second to last link.
I would do some more reading on the basics, or find some to explain it on a whiteboard.
Text is a dificult medium. :)
INDY72
Indianapolis, IN
Mesh could be used in Trunking for VoIP technology????
N
N_Jay
Guest
Lets not confuse the issue.
If we start with the basic terms then people can build a reasonabl understanding.
And besides, would VoIP on mesh realy be trunking?
Or is all packet trunking?
:wink: :wink: :wink:
INDY72
Indianapolis, IN
I was referring to using VoIP in trunking.. Would Mesh be the method of the VoIP on the trunking? Such as is used on P-25IP?
WayneH
Forums Veteran
Super Moderator
Your master site
Possibly a "mesh" microwave backhaul network is what it refers to?
-Wayne
N
N_Jay
Guest
-Wayne
Well I glad you have an idea what he is refering to, because I am lost. :wink: :wink:
Or could he be referingto the type of fencing around the site? :twisted:
This is like geiing into one of those What is digital and What is analog discussions! :evil:
radiogrrl
Australia
sorry for causing any confusion guys!
thanks for the responses though... I'm taking N_Jay's advice and doing a little more background reading... if I manage to answer my own question I'll let you know - if anyone's interested!
What I'm looking at is a current motorola trunking system with a microwave backbone and I guess I was just wondering if the MESH technologies (which I've only just started reading about) were an IP version of trunking sort of systems.
thanks for trying anyway!
Raccon
Simply put MESH networks are data networks where wireless clients can act as repeaters to link back to the system, to extend the coverage or to create a network on-site.
AFAIK developed for military use and specifically where you have no existing infrastructure (like on the battlefield). See here for more information: Motorola's Mobile Mesh Networks Technology
The abobe MESH networks are not to be confused with the mesh topology of transmission links that are sometimes used in trunking systems to link base stations and/or switches. Here the mesh does provide link redundancy only.
INDY72
Indianapolis, IN
TY for the info!
So MESH would not be the way to set up IP on TRS (VoIP/P-25IP etc). If you had no existing background infrastructure, then youd use the MESH to set up a net, then you could build out from there. I love learning new things. See N_Jay, old dogs can learn new tricks! (Bark bark)
n4voxgill
Silent Key
New Braunfels, TX
Mesh Networks produced a version for voice use. It was tested by one fire department that I know. The radios connected to each other as they came on the scene and were used for local communications. They worked good. Now motorola has bought Mesh Networks.
In the original story about Mesh Networks it was stated to VOIP could be used to make a city wide system.
I know that motorola has been developing plans for the 4 GHz frequencies that were recently released. I bet mesh will be included in this band and others.
