I've previously been monitoring a P25 trunked network (NSW Government Radio Network Trunking System, NSW Statewide and ACT, Multi-State - Scanner Frequencies) in my state using the non-affiliate scan method. I.e. I created the actual trunked channels and placed them in a scan list linked to a conventional channel. This has been working fine without any issues. The details for the trunked system were copied from the codeplug of a radio authorised for the network. The radio is an APX8000.
I've recently been given a unit ID to use on the network so it can legitimately affiliate. After changing the ID in CPS I went to test the actual trunked channel. It seems to affiliate with the network as I can see the signal strength indicator and shows a good RSSI reading. However, the radio does not RX (doesn't unmute or show the receiving radio ID), and when I try to TX it just gives me an invalid tone. Transmit mode is set to unrestricted in CPS.
Can't seem to figure out why this is the case, especially the fact that I can RX fine when used on a scan list for non-affiliate. I have searched long and hard over the internet however I couldn't find anything. Hoping someone here can shed some light. Let me know if you require any further details. Thanks!
