Trunking monitor/scan issues
ellwoodops
hello,
G2 pager with 1.3 firmware
Recently i have been having issues with my pager receiving my trunk tg monitor and scan. Previously everything worked okay, received all three channels i had set and now it cannot get any. it says im out of range, even when im standing next to someone with the same pager, on the same channel. Hopefully this is the right place to look for some help, and if you need any info i can try to provide it, although i am not super programming savvy.
edit: running VHF 136-174MHz antenna
blackbelter
Apparently lots of people having the same issue after loading the 1.3 FW . Perhaps you can revert back to 1.2,
blackbelter
Contact your dealer . Did you save your previous CPC and settings, as you would need them as well.
ellwoodops
I might have a save, but i did not notice much change or having to do extra programming after the upgrade. i will contact my dealer!.
i have a few exports of older programing saves. is there anything specific to look for that makes it known that it is a 1.2 save not a 1.3?
I also have the same version of the pps that was out when 1.3 was out if that makes any difference.
