Dts-96
Here is the blurb on the DTS-96
Main Product Highlights
500 Channels – 10 channel storage banks with 50 channels each
V-Scanner Folders – 11 500 channel virtual scanner folders
Simultaneous Multi-system trunking operation – scans conventional frequencies and trunked systems simultaneously.
Listen to Police*, Marine, Railway, Aircraft, CB Radio, Racing & TV Broadcast's.
Automatic Channel tracking – automatically determines the trunking system frequencies
Frequencies your scanner can receive – 26.965 – 27.405 MHz, 28 – 29.700 MHz, 50 – 54 MHz, 68 – 88 MHz, 108 – 136.9875 MHz, 137 – 174 MHz, 406 – 512 MHz, 806 – 960 MHz, 1240 – 1300 MHz
10 ID List banks - lets you store 1500 ID's in 10 ID banks, each with 5 ID sub-banks. 30 ID's are available in each ID sub-bank. ID test tags let you easily identify the user of a particular talkgroup ID code.
12 character 4 line display
Some good news: All emergency services on the North Coast (including police) remain analog.
The radio can also decode digital clear eg Police - Channel November - Lower Hunter.
Once you venture further south into Newcastle, Central Coast, Sydney, Illawarra, Blue mts the police are using encryption which can't be decoded.
The other emergency services remain on the analog GRN
I understand from other that the DTS-96 can't trunk track some of the control and voice channels
That is only an issue if you come to the big smoke of course.
Grant
