Trunking OSW
fireboy
texas
if your control channels are within 866-868 range and the radio works fine, and you add a zone where the CC's are in the 850 range and the radio wont key up unless the TG is idle, would you have to adjust the OSW? or is it something else I forgot to do in RSS?
wavetar
Why would you want your radio to key up while someone else is talking? Many Motorola trunked systems are set up so as to not allow that, which is probably what you're running into. Nothing you can change in the radio will affect that.
Todd
greenthumb
Colorado DB Administrator
I bet what he is saying is that the radio won't key up unil the hang timer on the trunked repeater has timed out. It doesn't have anything to do with the OSW, but I have seen behavior like this happen when the trunking personality is set to transmission trunking. If you change the personality trunking type to message or PTT-ID, it should take care of the issue.
fireboy
texas
Oh I totally forgot about that, after reading that I just remembered that I forgot to go and set it for message. thanks guys,
