scannerbox
Trunking Recorder v2.6.3061 has been released.
It can be downloaded at Trunking Recorder - Recording audio from trunked radio systems monitored by Unitrunker
This release contains the following changes
- Added option to create more than 2 Call Audio Streams.
- Moved Call Audio Streaming configurations to database.
- Added Custom MetaData format settings for each Call Audio Stream.
- Added sorting option when selecting Favorite or Streaming Talkgroups in the Configure menu (Click the column heading to sort).
- Removed the ability of Voice receivers to show their MetaData in the Trunking Recorder application title bar, the first Call Audio Stream will still show MetaData in title bar. All Call Audio Streams can write MetaData info to a text file for use with streaming application.
- Added "OR" or "AND" call searching option to webserver configurations for how calls are searched when multiple different search options are selected at same time. Default will remain "OR".
- Added option to Call Notifications to allow setting the minimum call length needed for a notification to be sent. Existing notifications will be set to require a call minimum length of 1 second.
- Added "Site" search option to web interface.
- Added capturing the "Site Label" information when using Unitrunker V2.
- Added "Site Label" to custom metadata and filename configurations.
- Fixed incorrect recorded call length when using MP3 format and a bit rate other than 16.
- Added process to detect remote desktop and console session disconnects so recordings can be restarted. (Remote desktop causes sound cards to get reset)
- Added option to webserver configuration that allows displaying the "site label" column on the web interface. (Hidden by default)
- Fixed caching of email templates when sending a call notification to reduce memory usage.
- Fixed issue where a duplicate call would not get recorded if a custom filename option was used and the length of filename generated was longer than 260 characters.
- Fixed issue where webserver would crash sometimes if it received connections from multiple different ports.
- Fixed issue where Call Audio Stream audio could play back on the wrong output when a soundcard was added or removed once streaming was already started.
- Added check to make sure Call Audio Streaming audio doesn't get stuck playing back a call.
- Updated WebSocket call broadcast data format to use the call list data format.
- Added delayed loading of Groups and Systems search options to improve web interface loading performance.
- Fixed issue that prevented recorded calls from being played on web interface if the filename contained special characters.
- Fixed issue that prevented handling of invalid SystemID values.
- Updated LAME MP3 library to 3.100.2.0.
