trunks on an analog
KK4DUY
Norcross, GA
Since I got my FCC license I've been nosing about the bands, and doing some reading here and there.
I have a question, apropos my thread title: is it possible to monitor a trunking system at all with an analog receiver? From my understanding the RX/TX may be split, and they could jump around - but are they typically digitally encoded as well?
DickH
Trunking systems can use analog or digital. Yes, they can be monitored with a conventional (non-trunking) scanner with varying degrees of success. Put in all the freqs. as conventional freqs., then lock out the control channel (strong, constant buzz). Every time someone keys a mic, the freq. may change, so you will need to keep pushing the scan button to try to follow the conversation. If the system is not busy you may have some success.
KK4DUY
Norcross, GA
What kind of FCC license?
Amateur Radio, General
Ah, thanks!
My radio has two receivers that can scan independently, and I can configure it to hold on an active find until the carrier drops. I'd imagine, like you said, things can get crazy if they are busy.
I'm using a Yaesu VX-7r if anyone is curious.
