TRX-1 Advanced Settings Questions
n2nov
Staten Island, NYC
I am following the new NYC P25/Phase 2 system and am trying to resolve sputtering audio and tracking issues. I see several places in the Advanced Features tab which might be helpful, but information on what each does and why a particular setting is used is lacking in the manual or in online searches. The settings that I am looking at are (my current settings are shown):
Search AGC (enabled)
Global AGC Mode (global)
Global AGC (enabled)
DSP Level Adapt (128)
ADC Gain (-2db)
DAC Gain (-4db)
Zeromatic Threshold (1180)
Zeromatic Slope (520)
Zeromatic Delay (50)
n2nov
Staten Island, NYC
GTR8000
NY/NJ Database Guy
BEE00
Yes, the system (not so new anymore, btw) consists of two primary cells (UHF and 800), both of which are simulcast.
n2nov
Staten Island, NYC
Straight from the help file that Ubbe said to look at. Nowhere does it say what the DSP settings are, what the changes would actually do and what situations they should be changed (same for Zeromatic settings). This is what I meant when I said it was lacking. The online manual at marksscanners site does not provide this detailed information either.
Advanced DSP Settings:
Your scanner contains a digital signal processing (DSP) chip that handles the decoding of digital data. The settings in this area control how the audio is fed through the DSP chip.
ZeroMatic Settings:
This option controls how the scanner tunes to a frequency. It is recommended that you use the default values unless you really know what you are doing. Click on the Load Defaults button to set the radio back to the default values.
There are three settings available:
ThresholdThis is the DC offset setting. Defaults to 1180mV. User-settable from 900 to 1500 mV.
SlopeThis is the voltage vs. frequency error ratio. Defaults to 520. User-settable from 450 to 600.
DelayHow long after detecting RF squelch we start checking Zeromatic. User-settable from 10 to 250 milliseconds. Defaults to 50ms.
Ubbe
Stockholm, Sweden
I have to agree on that. There's no advise how to adjust the parameters and how you can detect if one setting needs to be adjusted.
The DSP and ADC only works for P25 modulation and not for NXDN and DMR. I don't know if that's a bug or are done intentionally to not allow adjustments in other protocols. ADC are the audio level to the decoder chip and if you are familiar with DSD+ you feed that software with an audio signal from a receiver and that receiver can usually be adjusted in volume level. To be useful the ADC really needs to be set individually for each site and not globally as it is now.
The DSP setting I believe have been explained as being the sampling rate that the DSP processor uses to sample the digital signal but I do not know why its highest setting are not the best. I haven't seen any other explanation for the DSP than being sample rate but it would make more sense if it where the level where it detects the signal, on just the top and the bottom of the signal curve or more towards the middle center line. Then the middle of the road level would be the best for a clean strong signal and a noisy weak signal could need a lower value and an interfered signal, like in simulcast, could need the highest value, but where it still decodes, by testing the highest value and then lower it in steps until it starts to decode.
Zeromatic are the function to let the scanner only react to frequencies that are spot on. In scanners that do not have that function you can often receive distorted signals from an adjacent frequency if they are strong enough. Every FM demodulators has a DC voltage component that follows the frequency carrier. If the frequency are spot on the DC voltage are exactly in the middle of the range. Whistler assumes this to be 1180mV. When the frequency drift to the side, slightly higher or lower in frequency, the DC voltage will change. My TRX-2 scanner are off by 1KHz in the 400MHz band and I would need to change that 1180mV to some other value to make that a new center point. It's probably some hidden service mode that can show the current DC voltage when monitoring a known good frequency reference and then set the Threshold correctly.
The Slope setting tells how much the voltage will change when the frequency are off and will make the window where it accepts the frequency to be correct either more narrow or wider. The Delay have to be used to let the scanners receiver settle down after a frequency change and could take different times dependent of component tolerances. If setting the time too short it could discard a correct frequency as being off by too much but having it too long will probably hamper scanning rate and also unmute the audio too late.
/Ubbe
n2nov
Staten Island, NYC
Here are some wiki pages that I found that might help (at least they have a little more info than the scanner's
manual or the EZscan software help pages). I will try them out after I get home from work today.
