TRX-1 and EZScan Questions
Davey1
Bowling Green, Ohio
I have a couple questions about the EZScan software.
When adding talk groups to a trunked system there is an option on the right side of the window to import talk groups from a text file. What is the necessary format of this text file? Is there any example available somewhere that I haven't found? I would like to use it if possible but don't know how to set up the file.
Also, when a trunked system has multiple sites, is there a setting to scan through all of the sites during each scan cycle, or to just lock onto the strongest site? If the option is available I am unable to find it.
Thanks.
lakeside121
greenwood sc
for me
took me a bit to figure this out use comma and quotes works for trunked to well for trx2 anyway
FREQ,"ALPHA",MODE
ex 452.100000,"COLGATE PALMOLIVE CO",DMR
lakeside121
greenwood sc
from clipboard it works i cant seem to get import to work on this new version of ezscan but all you have to do is select the bar at top TGRP and alpha tag
ex 45301,"mobles to base",
mikey60
Oakland County Michigan
There's a listing of the fields in the help file under the tab reference area. Look under the convention and trunked tabs for these.
Mike
RDGDigital
MD - Eastern Shore
