How can i save TRX 2 program and put it on TRX 1?
thank youUnder the file tab save configuration to archive on the TRX 2 EZ Scan, open TRX 1 EZ Scan and go to file tyab and select restore from archive and choose file you saved.
what folder is it in ?thank you
Depends where you save itwhat folder is it in ?
CDAT / DP / ITMP / LBD / PRESETS ? which one i just said to save to archive it didnt let me choseDepends where you save it
NONE OF THEMCDAT / DP / ITMP / LBD / PRESETS ? which one
You set the name and folder when you save it, it automatically places it where it needs to be when you restore itwhat folder is it in ?
when i clicked to save as archive it didnt let me chose any place v-scanner folder ?You set the name and folder when you save it, it automatically places it where it needs to be when you restore it
i click it like you did but it dont bring up the other window
Don't know why it wouldn't, sorry can't help then not sure what would cause the issue. I use four versions of EZ Scan and swap configurations between scanners on a regular basis using this method.i click it like you did but it dont bring up the other window
im using whistler trx1 and trx2Don't know why it wouldn't, sorry can't help then not sure what would cause the issue. I use four versions of EZ Scan and swap configurations between scanners on a regular basis using this method.
As do I, along with WS1098 and WS1080, that is the four versions of EZ Scan I mentionedim using whistler trx1 and trx2
what is the v-scanner for ?As do I, along with WS1098 and WS1080, that is the four versions of EZ Scan I mentioned
im trying to copy trx2 to trx 1 different easy scan program ?Read the data from the radio you want to copy, disconnect the radio. Connect the other radio and send the data to the new radio. You can also read the original radio and create a new sd card to put in the other radio.
YESim trying to copy trx2 to trx 1 different easy scan program ?
