TRX 1 and TRX 2
Under the file tab save configuration to archive on the TRX 2 EZ Scan, open TRX 1 EZ Scan and go to file tyab and select restore from archive and choose file you saved.
javfd
nw arkansas
You set the name and folder when you save it, it automatically places it where it needs to be when you restore it
when i clicked to save as archive it didnt let me chose any place v-scanner folder ?
i click it like you did but it dont bring up the other window
Don't know why it wouldn't, sorry can't help then not sure what would cause the issue. I use four versions of EZ Scan and swap configurations between scanners on a regular basis using this method.
javfd
nw arkansas
im using whistler trx1 and trx2
jaspence
Michigan
Read the data from the radio you want to copy, disconnect the radio. Connect the other radio and send the data to the new radio. You can also read the original radio and create a new sd card to put in the other radio.
javfd
nw arkansas
im trying to copy trx2 to trx 1 different easy scan program ?
