- Joined
- Feb 20, 2003
- Messages
- 1,231
- Reaction score
- 97
How have you all been getting to the TRX-1 battery compartment?
With much difficulty!!! Seriously, best way I found was remove the antenna and pop out the bottom of scanner from case. It's not easy and you need to work at it. I'm not using the belt clip and that makes it easier.
To minimize repeating that process, I loaded the best rechargeable batteries I could find (Eneloop 2100nmh) so hopefully I don't have to open the back for a year or two. But I do like the case.
Hello,
I saw a post suggesting to take the insert plate out first and it makes it easier to remove the case to access the batteries.
73 Eric
Here is a small tip on the cases.
To remove the case, remove the plastic insert first. It will make it much easier to remove.
The case is a bit stiff at first but should become a bit more pliable as you use it.
I have been interested in the TRX-1. I have not seen one with the case, out of curiosity can the radio be used without the case so changing batteries can be done on the run. I too don't like to charge batteries in the radio and like the option of being able to swap out a set if needed.
Sent from my SM-G900R4 using Tapatalk
