TRX-1 DMR trunking color codes
jwpottberg
Sunnyvale, CA
<rant> I am in NYC with my TRX-1 searching and finding unlisted DMR trunk systems. I then add systems manually (no computer with me) and everything works fine except I can't select CC's for the trunk site's freqs. Apparently they default to "any" (which is good) but then they can't be changed. I know that this can be done via EZ-scan SW and can also be done for conventional DMR channels manually. The upshot is that I can't filter out unwanted traffic on shared freqs here in the field using a wildcard. Most of the time I can use TG's as filters, but not if the shared systems use the same ones. Anyway, I feel this is an oversight that could easily be corrected in a FW update. </rant>
