TRX-1 Issues
baboon53315
Oshawa,Ontario Canada
I have the PSRN system programmed in my TRX-1. Locks onto the control channel but won't lock onto the voice channels. I have the same system programmed into my PSR 800 and works just fine. All the updates are current on the TRX-1. Not sure what the issue is at this point. Thanks
Ubbe
Stockholm, Sweden
What does it actually do when it is supposed to go to the voice channel?
If you go to Global settings in the scanner and you set IF Out to HP you can then plug in an earphone and listen to what the scanner receives. You probably can hear if it goes to a channel without any signal or if the signal are too noisy to be decoded.
/Ubbe
