TRX-1, Keypad and Scan List
daysand
Houston Texas
I have read the manual and I have programed EZ-scan into the scanner.
I would think the numbers on the Keypad would be related to the numbers of a Scan List.
Example: press number 10 would enable or disable the Scan List number 10.
Have I missed this part about the Keypad being related to a Scan list or the scanner does not work this way?
gh6406
Dalton,Ga
Keypad and Scanlists
You are right. While scanning, if you only have scanlist 1 scanning, and you want to enable scanlist 2, you would just press 2. The scanner will then enable scanlist 2 and it will be scanning scanlists 1 and 2.
If you want to enable scanlists 2,3,4, and 5, you would press 2.3.4.5 and it will enable those scanlists. You have to separate the numbers with periods.
Hope this helps.
daddyjohn
Thank you very much for sharing this. I didn't know this and makes it so much easier.
Sent from my SAMSUNG-SM-T337A using Tapatalk
Anderegg
Enter text in this field
San Diego
And if you are scanning only scanlist 1, and press 1, then you get to learn how to use the TRX menu system. :p
Paul
