TRX 1 library question
nacsr
Rome,NY
New to TRX 1.If you import from the on board data base,are the frequencies already there for trunk systems or do you have to input them? In other words is plus get and play ,Or is something else required?
Thanks in advance
AggieCon
Texas
If it is a P25 system, you will be better off if you remove all but the active control channel.
