I have all 19 sites programmed into my scanner. I still get nothing. I do not see the "T", but I do have good signal strength from the towers on the scanner when it's scanning this site. I do have 19 control channels programmed into my scanner. Someone said I was missing a control channel. Which one am I missing? Also, what setting should I have for this site? Motorola, or Project25?
Okay I'm going to have to admit here I am totally lost as to what you are saying, we have answered your question and the problem is solved. We gave the answer why you are not picking up your County anymore.
You have been using the Motorola type ll smartzone system to listen to your police and fire previously before you lost the ability to hear them.
The reason you can't hear them anymore is because that system is not being used anymore, I assume you could just delete it from your radio. You are now on the tdma Phase 2 simulcast system that has three sites and no more than that. The name of the sites are scott, east and west.
You need to use your easy scan software from Whistler, make sure it's updated and simply program the new system for your county into your radio.
This is not something you're going to want to manually program, you want to use the easy scan software. I really don't know what else to say?
I don't even have easy scan programming software on my PC anymore but I do own a trx1 and it's sitting in a storage bin in my for 5 years, it does not work well at all on Phase 2 simulcast but I'm not going to sell it, I might find a use for it at some point. I stopped using it when my whole area went Phase 2 simulcast, it worked great on the Motorola smart Zone systems but they are all gone now like your countie's is.
If I could make a suggestion. Press the report button and have this thread moved to the Whistler forum. We have answered the question of why you're not picking up your county anymore but perhaps there they can help you properly use the Whistler easy scan software and assist you in putting in your new system that your county is now using.
I m familiar with programming the TRX and I also own a PSR 800 for over 12 years.
The guys on the Whistler forum will set you up. All the information is here on this thread that they need.
