chris451rr
I have 3 of these TRX-1 radios.
One of them would run fine for awhile then start giving an ERROR DETECTED message.
I thought I would try 'formatting card' then copy configuration to scanner.
Then it started showing an error after turning it on and beginning the scanning.
I thought, maybe there is a bit flipped in the firmware lets reload that.
OK using the TRX-1 software, I updated cpu firmware and dsp firmware.
I inserted a fresh formatted memory card which had configuration copied to it (via SD card reader not via USB).
Turning it on, a message updating firmware came on.
Pull out the battery and turn it on again, same thing "updating firmware" ... update failed.
I did a search for 'cpu update mode' which landed me here, I saw one place it said hold menu and plug in USB.
That did not work, same 'updating firmware' again and again.
I pulled out the battery and held menu key on the radio, and put the battery back in, finally CPU UPDATE mode.
Now the program was able to update firmware, and this time it succeeded. The first try failed, but changed cables and tried it again this way. Pull battery. Hold menu. Put in battery. >>>> CPU UPDATE mode.
I also updated DSP the first time and it looks like thats OK and its running now so that did work the first time.
Very hit and miss to get the updates to work.
To sum it up: Radio crashes with ERROR DETECTED 4-04.Select a new short USB cable.
Use a new SD or reformat the existing SD(8GB) without quick format checked with trx-1 pc app.
Copy configuration to the SD with the USB cable or by pulling the card and use a USB to SD adapter.
Update CPU and DSP even if its the latest version it will reload it.
If the update fails use CPU Update mode by pulling power and USB and holding menu, power back up(battery preferred). Perform update check and do the update even if the latest version shows.
It looks like its staying up and running for a half hour now, without the crash.
I'm going to make a backup card of current configuration using an older 8gb SD,(probably had trouble with that card too). I'll do the (not quick) format on it and copy configuration.
I have 16 virtual scanner folders. A lot are very old, and I have to try them all to find which one is the latest one.
I am looking for how you see which virtual folder the radio is starting with.
