TRX-1: Trx-1 stopped recieving
Louwo
Morris County, NJ
A little background.
It's a TRX-1 ive had a few months now. I drive all over the county for many years listening to the Morris County Trunked system. Usually pd 1 and 3. I know where some areas it gets choppy or im out of range. I used to run with my rs 2096 till this LSM took place and i figure time to get a p2 capable scanner.
This trx from the beginning in and out catching maybe 80% of transmissions trying all of my different antennas indoor and one on the roof. So I just accepted it kept trying to change a setting here and there with minimal improvement.
Now I am getting nothing on this system. The signal bar could be all 5 to 4 with the T showing and it still is not receiving any audio it is not pausing on any talkgroups. None are locked out. This is in areas I was getting loud and clear constant transmissions.
I just can't figure out what changed either by county or why is this scanner not allowing anything to receive.
Any ideas anyone familiar with a LSM Trunked system with a TRX-1?
try
Mine did this, all I did was go into settings and reset the settings to default.
Louwo
Morris County, NJ
Sorry It has taken me a while. Crazy with work. I appreciate if a fix can be found. heck 80% of coms is better then none with this LSM system that I am mobile with. Here is my archived File I have so far. My main issue is with MIRS. Morris county NJ trunked system. I am not new to listening to this system just been having a lot more issues when they went to the LSM System.
It appears the 453k have overloaded the 195k File limit........ Ill send it to you if I can.
Louwo
Morris County, NJ
With help from troymail he helped with odeas for what setting I changed. I had my trunk tables set to normal that I did change. Works as it did now when set to auto fill. Thanks again Troy
