My old PSR-800 is running circles around my TRX-1 on a local P25, phase-1, LSM trunked system.
The TRX-1 seems deaf to signals that the PSR-800 picks up loud and clear. The TRX-1's signal-strength meter registers full bars while receiving this system's traffic, but virtually no audio comes through. The TRX-1's "T" display icon (indicating that it's receiving control channel trunking data) flashes intermittently on this system, but so does the "S" display icon (indicating that the "squelch circuit is open DMR"). I definitely don't understand why the "S" display would flash during reception of a P25 system, but this issue may be key to understanding and fixing my problem.
The TRX-1 does a beautiful job with other conventional and trunked P25 signals (the statewide Colorado system, for example, and I've been very happy with its ability to follow local DMR signals.
The only difference in settings that I can discern between the two is that the PSR-800's DAC gain is set at 0dB (the default setting) while the TRX-1's DAC gain is set at -4dB (the default setting). Setting the TRX-1 DAC gain to 0dB doesn't seem to make any difference in reception.
Any thoughts, ideas, or suggestions would be welcome!
Thanks.
-Johnnie
Thanks.
-Johnnie
