TRX 1 Wall A/C
flody1
willisville.il
Do I need another wall adapter with this , I see they sell one for it at Amazon?????? I will run it off my big ant most off the time but want batteries charged if need to go outside etc. Thanks mu 1st post !!!!!!!
I know it comes with the cable but I'm not sure about the charger. I've had mine for 2 years now and have used my computer USB port, regular cigarette lighter charger, and home USB charger from my cellphone and have never had a problem with it.
Sent from my LG-Q710AL using Tapatalk
jaspence
Michigan
Charger
Any reliable USB 5v output should work. If you check the forums, you will find that many scanner users prefer a good external charger for battery charging. Disable internal charging when you want to run the radio using USB power.
DJ11DLN
Mudhole, IN
X2 on every word.
