TRX-2 Error Message
Jphila20
Retired LE. Honor our Fallen.
Southern Lorain County, Ohio
When copying from the Micro SD card to the computer I get this error - Value must be between 1 and 2147483647". I am placing the card in the SD reader in my computer. I have done this before with no issues. This card has been in use with my TRX-2 with no issues. If I put in a different SD card, which I have used before, I don't get this error. I know there was an issue with this error a while ago, but I couldn't find the post.
I keep multiple cards as backup and can't figure this one out. One works - One doesn't.
Thanks!
Didn't you post about this last year?
Ubbe
Stockholm, Sweden
The data on the card are corrupted in one of the files. It's probably nothing wrong with the card and it's a file system problem, that the scanner made a mistake when writing a file. Reformat the card using SDFormatter and load the data to it again.
It probably can happen if you have the scanner in a vehicle and start the car while the scanner are powered on and battery voltage drops too much.
/Ubbe
