TRX-2 import from another Whistler scanner
White Bear, Mn.
I remember I did this from a PSR-800 to a WS1098 by changing a file name but, cannot remember what that was?
I should have took notes.
Is it possible to import the PSR-800 files to a TRX-2?
Whistler_Support
Whistler Representative
Cincinnati, OH
There is no need to change file names. Save your configuration in the PSR-800 then import the configuration to the TRX-2.
Next, select Restore Factory Defaults on the General Settings page, then set the scanner features the way you want them, then copy configuration to scanner.
White Bear, Mn.
O.K. good deal, Thank you.
