RocketNJ
Hi All,
Picked up a TRX-2 when they had the flash sale a few weeks ago. I already have a TRX-1.
My local PD is using a conventional DMR RAS enabled repeater. The TRX-1 decodes almost all of the transmissions using the stock antenna (UHF 450 freq.). The TRX-2 is missing more than half the transmissions. I've compared with both on at the same time.
I've tried with both loaded from RR database and also with TRX-2 set for wildcards for TS, Color, and TG. No difference.
Both have latest CPU and DSP firmware loaded.
Decoding of the county P25 system is fine on both so doesn't appear to be a sensitivity issue.
Any ideas?
Any ideas?
