In the scan list, Suffolk Fire, is there any differentiation between the fire dept divisions because it looks like you have all (339) Suffolk fire freqs in one list. I'm not saying it's your problem, but the scanner is scanning a ton of freqs that are well outside its reception area. I am not sure how long that scanner takes to scan all of those freqs but it will most likely result in missed comms. I would at least program the freqs in groups by Division so you can have your scanner not scan stuff that's too far away to receive.
Just to note, all of these are in use on the 800 side of the P25 system.
| DEC | HEX | Mode | Alpha Tag | Description | Tag |
| 85 | 055 | D | FRES Dispatch | Fire/Rescue/Emergency Services - Dispatch | Fire Dispatch |
| 161 | 0a1 | D | FRES Command | FRES Command | Fire-Talk |
| 20161 | 4ec1 | D | FRES Command | FRES Command | Fire-Tac |
| 163 | 0a3 | D | FRES Ops 1 | Fire/Rescue/Emergency Services - Ops 1 | Fire-Tac |
| 165 | 0a5 | D | FRES Ops 2 | Fire/Rescue/Emergency Services - Ops 2 | Fire-Talk |
| 167 | 0a7 | D | FRES Ops 3 | Fire/Rescue/Emergency Services - Ops 3 | Fire-Tac |
| 49 | 031 | D | HAZMAT | HAZMAT | Fire-Tac |
For all tg's listed in Fire East, West and Central, there is only a small handful of those tg's actually in use.
