TRX-2: Radio Only Runs With USB
k1jbp
ARS
West Warwick, RI
I have a TRX-2 that I got for Christmas. Last night I went to turn the scanner on, and it wouldn't start up. Figuring something was wrong with the wiring in my truck, I brought it in the house. By chance one of the suggestions was to upgrade the firmware because it might of gotten corrupted. When I did that, it came to life. Problem is now that it will only turn on if the USB cord is plugged in. I did try reinstalling the firmware, but it did not cure the problem.
Ubbe
Stockholm, Sweden
The USB cable will power the control head and it will work regardless of the main radio unit. You could have a problem with the connectors between front panel and main unit. Hold in the lock button and pull off the front panel and inspect the connectors. Perhaps the only thing needed are to "exercise" the connectors to get rid of any oxidation that could easily happen in a car.
/Ubbe
k1jbp
ARS
West Warwick, RI
/Ubbe
THe scanner is not even a month old. Taking the power cord off just freezes the display.
tvengr
Well Known Member
Baltimore County, MD
Try this:
· Unplug power cord from back of scanner
· Unplug USB cable from front of scanner
· Detach removable head
· Remove and then reinsert SD card
· Reattach scanner head
· Press and hold power button for 30 seconds (leave cables unplugged)
· Release power button
· Plug in power cord
· Press and hold power button until screen shows “Power on, release button”
k1jbp
ARS
West Warwick, RI
Try this:
I did as instructed. Held power button for 2 minutes to turn back on but still nothing.
west-pac
I will have to contact them then. Looks like no one has run into the particular problem before.
If you Google TRX2 power issues you'll see plenty of threads about powering on issues.
k1jbp
ARS
West Warwick, RI
Yes, I have done that. All say to disconnect everything, take the sd card out, and hold the power buttons for various amounts of time. But it is still unresponsive when holding the button for a second time to power back up.
buddrousa
Just a few questions when hooking up the scanner in your truck
RED to positive
BLACK to negative
Take a VOLTMETER and read to truck voltage motor off then read the voltage motor running.
Did the scanner turn off when you started the truck.
k1jbp
ARS
West Warwick, RI
Just wanted to send a follow-up. I wrote Whistler to ask them if they had any ideas. They didn't offer any:
Hi Glenn,
Please send the unit to the following address for service.
Whistler Group
Customer Returns Dept
1412 South 1st St
Rogers, AR 72756
IMPORTANT: Please include a note describing the problem along with your name, address, email address and telephone number. If you do not include this information, the repair and return of your unit may be delayed.
For service under warranty, please include a copy of your dated proof of purchase (cash register receipt, invoice, order confirmation, etc.). If dated proof of purchase is not supplied, service will be treated as described in the "Service Out of Warranty" section of your owner's manual and a customer service representative will contact you for payment if one is due.
If you include your email address with your unit an email will be sent to you when we receive your unit for repair. We will also send you an email to notify you when your unit is on it's way back to you after the repair has been made. If you do not include your email address these emails will not be delivered to you.
You can track your repair if you provided your phone number by going to our tracker section of our website.
https://whistlergroup.com/pages/check-repair-status
Note: Once we receive your unit it may take a few days for it to be entered into our system. Our turn around time is 2-3 weeks when the unit is returned with a dated store receipt showing its within the warranty period.
Thank you,
John
Whistler Scanner Support
Glenn Butterfield wrote:
My TRX-2 would not power on. I had it in my vehicle at the time. I brought it in the house, and hooked up the A/C adapter. It would still power on. Someone recommended reinstalling the firmware. The scanner powered up when I hooked up the USB cable. I did redo the firmware, but it didn't resolve the problem. MY scanner will only work if I leave the USB cord plugged in. Do you have a solution, where I can restore normal operation to it?
