Hello all,
I thought my setup would be perfect with everything mounted and all, but when a TRX-1 with a rubber ducky is outperforming all your mounted scanners, it is a bit infuriating.
So alas, I come to seek help with some issues I have ran into ever since I got my console install done in my Dodge Charger, and I'm going to give as much detail as I can. Essentially, my console consists of a Motorola XTL5000, a Kenwood TK6110 Low Band Mobile radio, and Three TRX-2 Mobile scanners that are remote headed in the console and go down to the floor of the car where the scanner units sit stacked on each other.
This may sound a bit ridiculous, but the scanners are attached to three Uniden bearcat 15-watt amplified speakers since they're so dang quiet. The scanners are all routed via three separate 3-foot RG58 BNC Male - BNC Male coaxes into a 4-port MCA204M amplified multi-coupler that routes out to a BR-137 Browning Tri-band antenna mounted in the trunk via a drilled in Eightwood NMO 3/4 inch Mount to BNC Male Coax Connector Extension Cable RG58 5M /16.4 feet.
So to simplify, 3 TRX-2 scanners > 3 RG58 3-foot coaxes > 1 MCA204A Amplified multi-coupler splitter > 1 16.4-foot RG58 Coax > 1 Browning BR-137 Tri-band antenna.
Everything is powered by a 12 way fuse block that is routed to the car battery in the trunk. The XTL5000 and Kenwood TK6100 radios are on separate antennas and coaxes.
So when I am scanning agencies like San Gabriel PD (P25 460.17500), Alhambra PD (P25 471.1375), or Monterey Park PD (P25 155.56500), they come in absolutely garbled on my TRX-2s. I can barely understand anything. However, when I turn on my TRX-1 handheld and put it in my cup holder with a rubber ducky, it comes in absolutely clear. The same issues can be said for the ICI Montebello Site (A trunked 470 - 483 MHZ system for those who don't know), where certain areas barely catch the Control frequency and intermittently show the "T" icon when I am well within the coverage area, but my handheld scanner is able to catch it better. Same can be said for the SBAY Site when I am in the middle of places like Manhattan Beach. Same goes especially for the Orange County CCCS 855 - 861 MHZ Countywide site.
So where am I going wrong, and is there anything I can do to improve what is going on with my given setup? Why is a small rubber ducky antenna inside my car shaming my extensive install?
