I'm trying to decide whether to purchase the TRX1 or SDS-100. I now have the WS-1088 and it does a good job, but I can't program NXDN systems.
What is your opinion?
jimg
jimg
There's no comparison.TRX1 or SDS-100
In my opinion if your 1088 works okay then the TRX series is a lot cheaper and comes with free NXDN and DMR.
Just my 2 cents.
To the OP keep in mind that maybe you don't have simulcast systems now in your area but do some research and see if anything you want to listen to is in the process of switching over to a simulcast system.if you don't have Simulcast systems in your area...buy the TRX
I own both the TRX-1 and the SDS100. In my opinion the only reason to get the SDS-100 is if you have Simulcast issues. Since you don't the, TRX-1 is the more cost effective solution.I'm trying to decide whether to purchase the TRX1 or SDS-100. I now have the WS-1088 and it does a good job, but I can't program NXDN systems.
jimg
The sds100 does operate while charging the battery.SDS-100 "Good Scanner"
Provoice Decoding very poor
Does track true DMR/NXDN Trunking
The fixed battery is drawback
and does not charge while in use
TRX-1 "Fair"
The antenna is very ez to snap at
the circut board and the board is incased in metal shield
it decodes NXDN/DMR Subaudiable not true
!! Get the 436HP !!
The only thing notes is
LSM Trunking
if you use LSM Trunking
the SDS-100 is the only scanner
to handel this for you
SDS 100 does charge while in use..go to battery settings and "Set Charge While On" option to enabledSDS-100 "Good Scanner"
TRX-1 "Fair"
!! Get the 436HP !!
LSM Trunking
I never had any issues decoding the one remaining Provoice system in my area, but individual results do varyProvoice Decoding very poor
TRX-1 "Fair"
!! Get the 436HP !!
LSM Trunking
"Fixed" isn't the word here. Fixed means not able to be removed. The battery is proprietary and though it can be removed I do agree it can be a drawback to not operate on AA's as does the 436. But the SDS's power demands are much higherThe fixed battery is drawback
Press menu button: Settings > Battery Options > Set Charge While On > Enableand does not charge while in use
