TRX1 Software for remote control and PC recording
ramboton
Tulare Ca.
I have a BCT15x, for it I use Proscan, with Proscan I can remote control the scanner and record to the PC
Is there any software with this functionality for the TRX1?
I am well aware that I can use the Whistler remote control demo, and use radiofeed to stream, and record to the scanner's SD card, so please do not offer these suggestions, what I am looking for is a software for the TRX1 that has the same feature set as Proscan.
Thank you
ramboton
Tulare Ca.
I tried iCopyRadio, while it is interesting it does not record to the local PC, it only allows you to upload the recordings after you copy them off the SD card, and I installed the client, but it is not allowing me to connect and remote control or listen to the audio, I am at work I will contact support when I get home.
