Trying to find a BNC adapter
mh34444
I need to find a female-female bnc adapter that I can mount inside a cubby hole in my car where my scanner is mounted. Basically I want to avoid drilling a bnc-male sized hole in the wall of the compartment, instead be able to drill a smaller hole that I can mount this adapter that would have female ends on both side. Antenna-->coax-->bnc male-->bnc female adapter |~wall~| bnc female adapter-->bnc male-->coax-->bnc male-->scanner. I hope that makes sense. I couldn't find it on radioshack's site. If there is something else you know of that would work better, I'd appreciate any suggestions. I just dont want the loose wire hanging there anymore.
Thayne
You probably will have to get that from a place like tessco or tally or hutton, but if there is any radio shops around they would probably have one. Definately don't pay more than $10
There is something called "bulkhead" types that you may want, you could have a nut on each side to keep it in the hole or just get the barrel type.
Hope this helps
pappy1
Central Arkansas
Try this place and put the info you need in the wizzard, if they have it it will show up. I get all my adapters from them.
whls3
Northern Virginia
Why not remove the connector and run it through a wire sized hole, reattach the connector and avoid the signal loss. Even if you have to cut off a crimp connector, you'll still be better off.
mh34444
Thanks, I'll try the shack in-store. As far as signal loss, I'm not too worried about it. Its simply a scanner antenna and I'm in an area with good repeater coverage on the 2 VHF frequencies I monitor.
Vern
Union County, GA
Radio Shack 278-115
The 'shack' has BNC F-F in plain and gold finish. The stock nbr above is the plain version for about $2.49 --
\/ern
mh34444
\/ern
Is there any benefit using gold over plain, or does it just make it look purdy?
N467RX
Panama DB Admin
Prescott, AZ
Well, gold is a better conductor, but be prepared to spend more money. For a gold BNC-F I paid like $6 and like $2.50 or so for a regular one.
