Trying to find this but can't can someone help?.
AngWay
Curious
Buchanan Co
I am trying to find This in sentinel or proscan but it's nowhere to be found it's called TWO WAY RADIO SERVICE CO. INC if you type it in they will show up, but why is it showing but it's not in the database. i know i'm probably missing something here but can someone else with more experience help me out some? Thanks
Enjoi19
Ontario, Canada
Everything in the database must be user submitted and verified - it cannot just be drawn from FCC data. So they may have a license but, no ones ever verified the use of the frequencies and submitted it.
  • Do not submit unidentified information. The RadioReference.com administration team prides itself on the accuracy of the database. Submissions with unidentified information will be rejected and not posted.
  • Do not submit data drawn directly from the FCC database or other sources. You must first personally verify that it is in use and the type of use before submitting the information.
You can see the submission guidelines here:
ecps92
Taxachusetts
Because that is from the FCC Database and there has been NO RRDB submission to include a PL/DPL/NAC etc, based on actual Over-the-Air confirmations that it is really in-use
AngWay
Curious
Buchanan Co
Ohhhhh ok gotcha .. well i have identified a few and submitted them already so yeah .. good to know tho thanks.
This is what you showed us, it is from the FCC data in RR, you can manually program it, with the info found here, and when you have the required information NAC/PL/DPL/Usage/etc you can submit it to the RR database.
This is from the RR database, which is where Sentinel and Proscan pull data from
RMason
Colorado / Mississippi
Two Way Radio Service provides radio service to multiple agencies and businesses in the area. Some of these are included in the RRDB under the user agency rather than under the licensee - Two Way Radio. Here is an example:
FCC Database
Radioreference database:
You can try cross-referencing the callsigns and frequencies shown in the FCC database with the county pages in the RR database to identify some of these.
AngWay
Curious
Buchanan Co
FCC Database
Ok thanks thats good to know i did not know that. thanks for the help
