Trying to get the programed freqs on a Hytera PD402
kd5kky
Loveland
My company is using Hytera PD402 but the employee that dealt with programing them is no longer accessible. I have the correct cable, I assume, and I have the CPS software. I am having problems getting the USB drivers to actually recognize the cable. Does anyone have tips or tricks on how to get the drivers to load or a method for scanning the freqs + TG? I have a cheap freq scanner that I got the actual freq but I am assuming there are talkgroups assigned being that I get the indicator to light up on it when I key up from my DM-1701 on that freq. I also have a few SDRs that can assist in scanning the info I need. Any help would be greatly appreciated.
dazey77
easiest way is to read it but not sure why your not managing that. Normally I find that pretty easy on Hytera, just have to find the right com port. Its possible your using the wrong CPS. There are two, the proper CPS for the PD6/7/9 and one for the lower spec PD3 and I honestly can't recall what camp the PD4s are in
To scan for the DMR TG etc. The easiest is to pick up the freq with a freq scanner and then use a cheap chinese DMR with promiscuous mode to discover the DMR details. Examples Anytone 868/878, connect sys CS-580, modified MD-380, btech 6x2 and many more.
Pittsboro IN
I have had occasions where a PC will lose the USB connection even after programming 3 or 4 radios in a row.
Usually resetting the cable or switching USB ports works. The 402 uses a com port and about half the time CPS picks the wrong one. Device manager under windows control panel will show which port the PC picked.
The PD402i series has a version 5 firmware the old CPS will not work with. This looks to be related to a new chipset
that was used after the covid chip shortage. The PD362i has a similar issue.
