This is a question I have seen a lot of on these forums, and after hours of reading through posts and guides I have decided to make my own question.
I seem to be unable to figure out how to get trunking working on my Radioshack pro-164 scanner. Conventional channels are fine and work great. I am programming by hand because I do not have software or a usb cable either.
I am trying to program Thunder Valley Casino in Placer County, CA:
Thunder Valley Casino Trunking System, Lincoln, California - Scanner Frequencies
What I have done is set the band to motorola trunking, and put in the frequencies, set the channel to MO
No trunking is happening its acting like a conventional channel, but on the control channel for the motorola system. ...is there no way to do this by hand if it is a re-banded system? if not then what is the best software to use that is compatible with this scanner?
