trying to read Motorola MTX Using RSS
underlift
Canada
Does anyone know how to get around my software problem?????? "Can not read radio with older version of Software" I recently bought radio off ebay and the radio was programmed with a newer version of software. Are there anyway or ways of modifying the older software or blanking out the radio and reprogram it with the older software? if so, How?
b7spectra
EMS Dispatcher
Cobb County, GA
You will have to get the newest version of the sw. Like everything else, I'm quite sure it's available on the web, somewhere!
underlift
Canada
Mtx/rss
I used the 6.0 sw. Thats the newest I've seen any other way around it?
KT4HX
Spotsylvania County, Va
To my knowledge, you will have to have the same version your radio was programmed with or a later one. Once a radio has been "done" with a particular version, earlier versions cannot be utilized any longer with that radio. So you will have to look for a later version somewhere. If I am incorrect in my reasoning, I'm sure someone will let you know.
tampabayjon
Underlift:
Not knocking anyone here or their intelligence or qualifications in their respective fields, but you may want to check the Batlabs website & ask on their respective message board(s) as well for any software issues that the answers above did not solve. They also have a model information as well that may provide some help to you. In any case, good luck and god Bless.
loumaag
Silent Key - Aug 2014
Katy, TX
As this thread has nothing to do with Scanning Software, it is moved to the Motorola forum.
As tampabayjon points out, you would be better served to use a site more directed to Motorola Radios and Programming them then here.
avfd2922
Kentucky
What model MTX is it? If it's a 2000 then there is a Windows version CPS available for it.
wavetar
The latest DOS RSS version is 6.07.00. As another poster stated, the MTS2000 has a Windows programming software platform (called CPS) which the latest version is 1.10.00, I believe.
You can easily 'revert' the radio back to an earlier RSS version by simply cloning an identical model codeplug into the radio with the desired RSS version. So, find an identical codeplug which you can open in your RSS, and clone it in.
Todd
Seadoo
For the original poster of this inquery, do just like todd said. All you have to do is load a codeplug into the radio using the version of rss that you have without trying to read it. Just load the codeplug into the radio then you will be able to read your radio and do whatever you need to do to it. No need for newer rss.
grem467
Houston, TX
Keep in mind that anytime you blow in a codeplug from a different radio, a full alignment should be performed.
wavetar
That is only needed if you 'force' a codeplug in with LAB RSS. Regular cloning with RSS does not affect the alignment settings in the least.
Todd
