onetimephil
- Joined
- Aug 25, 2021
- Messages
- 38
so I downloaded the proscan onto my computer. What is the RR subscription that proscan mentioned above. I'll do it . I don't see how to in the manual.Thanks
Cheapguy mentioned a $15 deal but didn't say how to do it. Don't forget I'm 73 years old and not very knowledgeable about these things. Like I also said I couldn't find anyone in the PDX area to do it for me.
If you've downloaded ProScan, you have a 30 day free trial period before you have to either purchase it, or discontinue use. Don't expect anyone to give you their (purchased) software key. The one time $50 purchase gets you lifetime updates on the program, which supports multiple Uniden scanners. As you've purchased a Premium Subscription, you do not need a 'key' for that. Using ProScan, or any other software that supports imports from RadioReference, you log into the web service for importing via the same login & password you use here for RadioReference.I've purchased a premium subscription to RR. will someone send me a key?
I've got the RR subscription and the Proscan on my computer. I went to the manual and I'm up to my usual state of confusion as to what to do next. I got the cable hooked from the scanner to the computer. Kevin C listed the PGE frequencies earlier . Is there something I need to do to get those in the scanner? Thanks,Phil
Type in your User Name and Password then click Connect. Do you see the RR Subscription Status box show the status and the Connect button gray out or do you see a message?I've done what you said. I'm up to the sign in. A space says name?
Select the following:Everything is grey. it says United states and select nationwide system
I missed seeing this before. You may want to delete that system in the scanner and import again as I just layed out. I don't know if those were conventional or what.Actually, they are in the scanner. I just need to get the thing to scan them.
Download from the scanner to ProScan. If you already Imported the Portland PGE system then uncheck the option "Delete All Systems In the Database" so it won't be erased.I put them in from someone who helped me before. They all say group7. How do I delete them.
Thanks. I glanced at the screen name and they seemed similar.I don't think that was me. I have the BCD996P2.
