TwoToneDetect TTD Helper Script - SFTP/Twitter/Zello/Pushover/Cleanup
xicarusx
Sayre, PA
Hi,
I created a helper script for TTD. That can do a few different functions. Hopefully this can help others consolidate as it has with me. instead of multiple programs running and doing things. Now I just have TTD and this script to run additional functions when a tone is captured.
Here is the github repo for the script and a list of what it can do.
TTD Helper
Python script to add functionality to TTD. Designed for Python 3.7+ Raspberry Pi 3 or 4.
Raspberry Pi Dependancies
  • Opus Tools
    • sudo apt install opus-tools
Python 3 Dependencies
  • paramiko~=2.6.0
  • scp~=0.13.6
  • aiohttp~=3.7.4.post0
  • crypto~=1.4.1
  • TwitterAPI~=2.7.3
  • requests~=2.25.1
Installation
  • Open Terminal window
  • In home folder clone this repository
  • copy ttd_helper.sh to TTD directory
    • cp ttd_helper.sh /home/pi/TTD
  • pip3 install -r requirements.txt
Running
To run the script configure TTD to ttd_helper.sh for your Tone
  • Post-email Command: ./ttd_helper.sh "[d]" [mp3] 0
    • on this line we pass [d] (department name), [mp3] (mp3 filename), and pushbullet group token (0 if you are not using pushbullet or don't have a group for that tone)
  • This will run the command once the tone has been processed and emails have been sent.
Functions:
  • Upload TTD audio file to SFTP server
  • Send Notification via Pushover
  • Send a tweet via Twitter
  • Stream audio to Zello
  • Clean up old local and remote audio files
SFTP Upload
This is Required if you will be using the Twitter or Pushover functions. You will need the audio uploaded to a remote webserver where it can be accessed by a URL.
  • Your user will need proper permission on the folder you are sending the audio file to.
  • In my case I have the sftp user owning the folder/var/www/html/audio and www-data as the group and 775 permissions to make it writable as the sftp user.
Twitter:
Request API access for you account Use Cases, Tutorials, & Documentation Once you have access you will need four tokens.
  • API Consumer Key and Secret
  • API Access Token and Secret
  • Those will be placed in etc/config.py
Pushover:
Create a Application and group for each department. You will need each groups token as a paramater when telling TTD to run the helper script
Zello:
Create a developer account with Zello to get credentials. Set up a different account than what you normally use for Zello, as trying to use this script with the same account that you're using on your mobile device will cause problems.
For Zello consumer network:
  • Go to Zello Developer Console and click Login
  • Enter your Zello username and password. If you don't have Zello account download Zello app and create one.
  • Complete all fields in the developer profile and click Submit
  • Click Keys and Add Key
  • Copy and save Sample Development Token, Issuer, and Private Key. Make sure you copy each of the values completely using Select All.
  • Click Close
  • Copy the contents of the Private Key into a /etc/config.py.
  • The Issuer value goes into /etc/config.py.
  • The Account username and password also goes in /etc/config.py
File Cleanup
This will clean up local or remote audio files older than x days as set in /etc/config.py
  • Two seperate configuration sections "local" and "remote"
  • Can be enabled so local is cleaned and remote isn't or vise versa or not cleaned at all
/etc/config.py
  • audio_url: Base URL path for your audio files. Example https://example.com/audio
  • ttd_audio_path: The path to TTD audio folder. Example /home/pi/TTD/audio (no slash at the end)
  • local_cleanup_settings: Settings for local cleanup
    • enabled: 1 or 0 (On/Off)
    • cleanup_days: 7 (Number of days to keep old files before deleting)
  • remote_cleanup_settings: Settings for remote cleanup (SFTP Server)
  • sftp_settings: The settings for SFTP upload
    • remote_path: This is the remote path to upload to. Example /var/www/html/audio
    • sftp_user: stfp username
    • sftp_pass: stfp password
    • sftp_host: sftp hostname Example: example.com
    • sftp_port: sftp port number Example: 22
  • pushover_settings: Settings for Pushover function
    • token: Pushover API token
  • zello_settings: Settings for Zello upload
    • username: Zello Username
    • password: Zello Password
    • token: Zello API token
    • issuer: Issuer credential from Zello account (see above Zello Section)
    • private_key: Private Key from Zello Development copied between two sets of triple quotes """HERE""""
  • twitter_settings: Settings for Twitter Tweets
    • consumer_key: API Consumer Key
    • consumer_secret: API Consumer Secret Key
    • access_token: API Access Token Key
    • access_token_secret: API Acess Token Secret Key
DC31
Massachusetts
nice work. If you are looking for additional suggestions, try adding the functionality to publish to an mqtt topic. Use the python package paho-mqtt. Publish to a mqtt broker (mosquitto.org). Then use smart devices (outlets, lights, relays, etc) to subscribe to the topics. then you can easily make lights come on, doors unlock, doors open, alert tones sound, whatever you can imagine when the tone sets decode. Get smart devices that can be flashed with Tasmota. (News - Tasmota)
xicarusx
Sayre, PA
UPDATE:
I have added MQTT functionality. I can't figure out how to edit my first post to update the ReadMe. I added the requirement paho-mqtt and a handler to process and send MQTT messages to a broker.
Requirements for MQTT:
- SSL not currently supported
- Must be using a username/password authentication method (It is unsafe to allow anonymous connections to MQTT)
Pushover was changed and each Pushover APP/Group must be added to the new departments.json this is like tones.cfg. It should include each tone and the settings for each tone in json format. Check the file for formatting.
Running the app as a command no longer requires the third parameter of group_token for pushover. just "[d]" and [mp3]. Note [d] must be in quotes due to constraints of passing arguments to command line scripts.
xicarusx
Sayre, PA
UPDATE 9-2-2021:
Changes
Zello Settings
- delete_after_stream: 1 or 0 (On/Off) #deletes opus file after streaming
SFTP Settings
- delete_after_upload: 1 or 0 (On/Off) # deletes the mp3 file from TTD after processing all other functions and uploading to SFTP
MP3 Manipulation
Modify the MP3 that was output by TTD.
- Gain level
- Convert to Stereo
- High Pass Filter
- Low Pass Filter
- Append another audio file to the beginning based on tone decoded.
- file to append is determined in the "/etc/departments.json" settings for each tone
- "mp3_append_file": "/home/pi/alert.mp3",
- Normalize Filter
xicarusx
Sayre, PA
UPDATE 9-4-2021:
Changes
TTD_Helper config.py
tones_cfg_path = "/home/pi/TTD/tones.cfg" <- tones.cfg path for the new helper to generate the departments.json
generate_departments.py
This file will generate the etc/departments.json using your tones.cfg all you have to do is fill in the blanks for each department.
xicarusx
Sayre, PA
UPDATE 9-5-2021:
Changes:
MySQL and Web Interface:
Example: Bradford County Firewire
Stores calls in MySQL database and will display them via web interface using PHP and NGINX Webserver.
Installer script to make it easy to configure.
./install.sh
new settings in config.py
- mysql_settings: Logs Calls to MySQL so they can be displayed via Web interface.
- enabled: 1 or 0 (On/Off) Before enabling run install.sh
- mysql_host: MySQL hostname
- mysql_port: MySQL Port number
- mysql_username: MySQL Username
- mysql_password: MySQL Password
- mysql_databse: MySQL Database
MP3 Append Speech to Text Tone Name to MP3 File:
This function will add department name to the begging of the mp3 file using text to speech.
New settings in config.py
- mp3_appentext_settings:
