Tulsa TRS Control channels
N5TWB
Sand Springs OK
While I have to admit it's been awhile since I fooled with my RS Pro-95, it always worked in Tulsa and the control channels appear to be the same in the RRDB. So why can't I hear the old control channel data stream on any of those channels? I didn't think re-banding affected those.
Thunderbolt
Global Database Administrator
Moderator
Ann Arbor, Michigan
They may have switched to Project 25, which is 9600 baud data stream? If that is the case, your Pro-95 wouldn't be able to detect the new format.
73's
Ron
wx5uif
Broken Arrow, OK
Nope they are still using the analog system. They are using the 856.1125 control channel right now. (Alt control channel in the DB.)
peterjmag
Tulsa, OK
Bart,
The control channels for the Tulsa site are...
859.9375
858.9375
857.9375
856.1125
When the reband occured they deleted the 860.0000 channels and added some new ones on the lower end. As the way the system is the older trunktrackers work just fine. Like stated above by wx5uif the current control channel is 856.1125
N5TWB
Sand Springs OK
Thanks to all - I hadn't put in 856.1125 as the alternate so I'm feeling a little foolish for not having it in the radio. I'll do that now. Love this place and the helpful people on it.
One other clarifying question - the reband means that Kellyville, Coweta, and Owasso sites are no good for my Pro-95, right?
N5TWB
Sand Springs OK
OK, I put in 856.1125, put it in "Manual" so I could lock on the control channel and I hear nothing. The screen says "MOT: none" - thoughts?
