csxcp55
I am using a Ringo Ranger ARX-2B - without its radials - and tuned to 146MHz for receiving in the railroad band (160-161.5MHz).
The antenna seems to perform fairly well, but I have been toying with the idea of re-tuning it for 161MHz. That would involve shortening the elements, and adjusting the tuning ring at the bottom. I have an antenna analyzer, so can do this without a problem.
The question is whether or not it is worth my trouble to do this. There seems to be some controversy over whether tuning significantly affects the received signal strength.
While I realize that the best method to improve signal strength is to raise the antenna, I'm kind of stuck with it up no higher than about 40ft here in northern NJ. And there are lots of obstructions between me and the trains I like to follow, especially from the north.
So I'm searching for other methods to improve signal strength, while fully understanding that if the signal is being blocked by an obstruction, and isn't getting to my location in the first place, nothing I do, short of raising my antenna is going to matter.
Of course, re-tuning the antenna to 161MHz precludes my using it for transmitting on 2m (146MHz), as the SWR would be very high.
Your thoughts?
CP
Your thoughts?
CP
