SpaceForceCmdr
UPDATE: I got a Rig Expert AA-35. Expensive, but neat little device, and seems intuitive to use. It's very helpful being able to see what's going on. My FTDX10 will tune my antenna as is on 30, 20, 15 and 10m, and this seems to make sense based on my readings. My SWR isn't great on any band, but it's 11-12 on 40m, which explains why my radio can't tune it.
Here's some quick measurements I did at certain freqs, and the SWR at those freqs. Also, I attached a couple screenshots with a full sweep. I don't care too much about 15 and 10 meters, but if I could get 40m to fall into line, that'd be great. Also, 20m is very important to me, so if I could tweak that, too, I'd be happy. The biggest problem is my antenna seems to be resonant at 6611 khz, so that needs to be raised by around 600 khz. 20m is most resonant around 14.036, but at least it'll tune with my radio's tuner.
So, to raise the 40m resonance, it sounds like I can shorten the ends of the antenna by folding them back. Not sure if I need to loosen the nut on the egg insulator and move it? Or do I just fold back some of the extra wire that's hanging down beyond the insulator?
Also, to tune a band, I can try squeezing the corresponding trap. However, I'm confused as to which trap is which. I was thinking the traps closest to the center balun would be 10m, then next would be 15m, and the traps near the end of each wire would be 40m. Problem is, the traps have writing on them, and the labeling doesn't seem to match. For example, the traps labeled 40m are actually second from the ends of each wire. Maybe I'm misreading the handwriting, or maybe I'm misunderstanding the design of the antenna.
