Tuning into AO-51 "ECHO"
nexus
Mississippi
AO-51 (Amateur Orbiting Satellite Carrying Amateur Radio "OSCAR") is a very easy satellite to not only intercept comms from, but also to talk through if you have a ham license.
This satellite is basically a cross-band repeater using FM mode. The uplink frequency that earth stations transmit on is on 145.9200 mHz with a 67.0 hz PL tone. But for everyone who wants to listen to the satellite, we all need to tune our radios to the UHF downlink frequency of 435.3000 mHz FM, and no pl tones.
There are two basic things you need to know in order to listen in on this satellite.
1. You need to know your Long/Lat cordinates or your grid (grids are used by hams to determin a geographical area on earth's surface).
2. The location of the satellite and the time it will pass over your field of view.
If you don't know your LONG/LAT or grid square number, you can easily get that by going here: http://www.arrl.org/locate/locate.html
From that page you can enter in your city and state and it will give you both LONG/LAT and your grid square number. Then you will want to go to this site to get the list of passes for AO-51 to your location: http://www.amsat.org/amsat-new/tools/predict/
From there enter in your grid square into the box and click calculate and it'll automatically put yout long/lat in and then click pridict button. It will then show you the next 10 passes for your location. Keep in mind the time is listed in UTC (universial time cordinate) and that means you need to ADD 5 HOURS to your local time to get UTC. (example. if its 1400 hours your time, in UTC it will be 1900 hours)
Pick the time you want to go listen to it, and select the live tracking link to actually see the track of the satellite. As it is fixing to pass over you, go outside (if its a portable) and first tune 5khz ABOVE the center freq (435.3000) so you'll be on 435.3500 mhz as the bird gets above your location you'll need to be on center (435.3000 mhz) and as the bird is leaving from your location you'll want to tune DOWN 5khz to 435.2500 mhz.
The reason for this is the doppler shift effect. You should get a good 6 to 7 minutes of monitoring on each pass... Also if using a portable radio with a telescoping antenna or rubber duck, be sure and try to keep the antenna in a slight angle to the ground, say 35 degrees or so. If you hold it completely vertical it won't pick up the bird as strong. So holding it at an angle will give you best results. If you are using a mobile mounted antenna or a mast mounted antenna don't worry about it. Hams have been known to get into the AO-51 with a mobile. So it can be done. And I've personally intercepted hams talking through it using a rubber duck on my handheld.
Good luck and enjoy...
W8OSP
Gallia Co Ohio
orbitron software, th-d7 kenwood ht, arrow dualband handheld yagi im ready! hehe
I think ive tried to work it before but no success, im usally on ISS packet.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Hi Jayson - what's Orbitron? If it's any good, please be sure to add it to the Satcom wiki
73s Mike
eorange
♦RF Enabled Member♦
Cleveland, OH
Nexus, great summary. I've worked QSOs on AO-51 with my 5 watt FT-60 handheld and an Arrow yagi specifically cut for the V/U modes.
Check www.amsat.org to see the AO-51 schedule. Sometimes (for transmit by us) it's in QRP mode, sometimes not, and sometimes it's down completely. Also, you can go to www.heavens-above.com , then Satellites...Radio Amateur Satellites, then AO-Echo (same as AO-51) to see the scheduled passes in your area. Once, I even saw it as I was trying to work it!
You can definitely pick up AO-51 transmissions with a whip and a scanner, no problem. Satellite operation is very cool, especially considering when you transmit you're sending a signal over 800 miles up - and you only need a Technician license to do that!
K0ATC
Oklahoma
I have a similar set up with a VX-7R and the Arrow. Havent worked you yet Erik, its tought getting in there some times, the big boys that use too much power stomp on your signal. I have a yaesu G-5500 sat rotator in storage and hope to get it set up and then use my IC-7000 to work it. Then i'll do the stomping LOL, no not really I just like to get one or two QSO's per pass.
eorange
♦RF Enabled Member♦
Cleveland, OH
You got that right, I hate it when inconsiderate hams hog the pass. Ah, but that's part of the challenge, working your way in!:p
gcgrotz
Savannah, GA
I hate to be picky but UTC conversion depends on which time zone you're in and whether DST is in effect. From EST, it is +5 hours, for EDT it is +4 hours. Add another hour for Central and so forth to the west coast.
In addition, the freqs you give are +/- 50 KHz, not 5, which would be 435.305 and 435.295.
You will get better results if you're not 1 hour and 45 KHz off.
Edit: Having said all of that I realize I should get off my lazy backside and try it myself!
